91 eclipse timing belt broke please help
91 eclipse turbo 2.0 the timing belt broke when pulling out of my driveway. do i need to pull head off to check for bent valves or does this motor not bend the valves when it bakes?
RE: 91 eclipse timing belt broke please help
they might have just tapped them and not have any damage. put a new belt o and do a compression test and see what happens.
i hope nothing happened i went to let out on the clutch and it cut off.
thats where i would start. where are you located?
South Carolina
I would check the timing and if its off, pull the head and check for bent valves. Your pistons should be fine.
I'd pull the head just in case, better to be safe then sorry.
