91 eclipse timing belt broke please help
Old Jul 27, 2008 | 09:43 PM
mack29730's Avatar
Default 91 eclipse timing belt broke please help
91 eclipse turbo 2.0 the timing belt broke when pulling out of my driveway. do i need to pull head off to check for bent valves or does this motor not bend the valves when it bakes?
Old Jul 28, 2008 | 06:42 PM
93eclipsegsx's Avatar
Default RE: 91 eclipse timing belt broke please help
they might have just tapped them and not have any damage. put a new belt o and do a compression test and see what happens.
Old Jul 29, 2008 | 12:24 AM
mack29730's Avatar
i hope nothing happened i went to let out on the clutch and it cut off.
Old Jul 29, 2008 | 07:56 PM
thats where i would start. where are you located?
Old Jul 30, 2008 | 08:05 AM
mack29730's Avatar
South Carolina
Old Jul 30, 2008 | 11:57 AM
dsm1990gsx's Avatar
I would check the timing and if its off, pull the head and check for bent valves. Your pistons should be fine.
Old Jul 31, 2008 | 11:48 PM
dsmtnr's Avatar
I'd pull the head just in case, better to be safe then sorry.
Jeff Kushner
Dec 27, 2015 05:22 PM
shownuff80
Jul 6, 2014 08:59 PM
marx88
Jun 30, 2011 03:54 PM
thuband
1st Generation
May 19, 2011 07:59 AM
tom93
1st Generation
14
Oct 29, 2008 01:59 PM
