timing belt broke
Old Sep 11, 2014 | 07:27 AM
Jeff Kushner's Avatar
Default timing belt broke
I have an 04 outlander with the mivec. I have replaced the timing belt at 70k miles and a whole kit at 140k. It know has 175k and the belt broke. I am putting on a rebuilt head as 2 of the intake valves bent. My question is how well do you think the lower half will hold up after redoing the top end. I run a parts store and have gotten mixed answers from local mechanics. Has anyone experienced this before? Thanks for the advice.
Old Sep 11, 2014 | 01:23 PM
Akzle's Avatar
if the valves bent on pistons (one cyl?) then the pistons will need replacing.
It would be good to check the con rods for fractures too.
Else, if it turns over by hand smoothly, you can assume the bearings are ok.
Id be hitting up whoever supplied/ fitted the cambelt. 30k is less than half of what id expect of one.
Old Sep 11, 2014 | 01:25 PM
Akzle's Avatar
also, if the valve guides and seats are still good, you can replace them, save the expense of new head.
Old Sep 11, 2014 | 08:10 PM
Two intake valves bent. I believe numbers 3 and 4 cylinders. The pistons had barely a mark on them. I thought about just replacing the valves but by the time you figure it out its not to much more for the rebuilt head. It is also quicker to get the rebuilt one. I have filed a claim and awaiting their answer. Do you think the bottom end will hold up with the fresher top end?
Old Dec 27, 2015 | 05:22 PM
Benckj's Avatar
Should just slip in place snugly. Nothing should have been machined at this location. Try polishing parts with scotch pad and using some light oil or grease to help slip in place.
Jim
shownuff80
Jul 6, 2014 08:59 PM
marx88
Jun 30, 2011 03:54 PM
thuband
1st Generation
May 19, 2011 07:59 AM
tom93
1st Generation
14
Oct 29, 2008 01:59 PM
mack29730
1st Generation
Jul 31, 2008 11:48 PM
