Install a USB Port or Bluetooth for 2014 Outlander
Old Dec 22, 2015 | 10:37 AM
Rob Righter's Avatar
Default Install a USB Port or Bluetooth for 2014 Outlander
I just purchased a 2014 Outlander ES. The radio has a media button and when I press it, the screen says "No Usb Input". I looked in the center console and there is no USB Port. What parts do I need to install either a USB Port or a Bluetooth input? For past vehicles I have installed GROM audio devices but GROM says they only make compatible devices for 2013 Outlander and older. Does anybody have suggestions?
Old Dec 27, 2015 | 04:59 PM
Krakker's Avatar
Do you see a cig light plug in (like for a cell phone) in the center console?
Both my wifes 14 and my 16 have a power port there that's got a cover on it, and the USB port is there also.
I plug my music into it and that's pretty much all I use for tunes when driving. There should be a little plastic cover/door to lift up at the back of the center console/arm rest.
Old Dec 28, 2015 | 12:09 PM
Mine has the cig lighter in the center console but I do not see a USB port. I had expected there to be one but unless it's totally hidden, I don't have it.
Old Dec 28, 2015 | 04:10 PM
Krakker's Avatar
Well I checked my wifes 14, and I check Edmonds.com and checked out the specs on 14's. I took a pic of the wifes center console, one of the front key port area, and one off the brochure photo's from Edmonds, and it shows it "without" the USB port.
I imagine if you have Bluetooth capabilities, you could get a cig lighter input that has a USB port on it, you could get it to work.
Otherwise your looking at getting a USB port added in from a stereo shop most likely.
Attached Thumbnails Install a USB Port or Bluetooth for 2014 Outlander-wp_20151228_15_24_52_pro.jpg   Install a USB Port or Bluetooth for 2014 Outlander-wp_20151228_15_25_03_pro.jpg   Install a USB Port or Bluetooth for 2014 Outlander-capture.png
VPower
Feb 17, 2015 06:45 AM
Idz21
Jul 1, 2014 07:42 PM
Rudeytwotone
Jan 8, 2012 04:04 AM
supermanu_l
Apr 8, 2011 02:08 PM
p6793026
Sep 23, 2008 02:38 AM
