Auto Power Inverter with USB Power Port
Old Jul 31, 2008 | 11:26 AM
p6793026's Avatar
Default Auto Power Inverter with USB Power Port
for the outlander, in the center console, you can put in a auto power inverter with USB power port, can anyone confirm it if woudl fit?
i just don't wnat to get it and then not fit beacuse it doesn't have enough clearance.
http://ca.en.kensington.com/html/14605.html
Old Jul 31, 2008 | 06:29 PM
ruchuck's Avatar
Default RE: Auto Power Inverter with USB Power Port
I dont think it will fit but it might.
Might want to bump the w from 90 to 150
________
easy vape
Old Sep 8, 2008 | 02:20 PM
azchipka's Avatar
Wont fit
Old Sep 9, 2008 | 11:28 AM
n0c7's Avatar
Another option - the iPhone comes with a cable that is iPod to USB, and an adapter for USB to wall power. This would fit and probably supplies the typical 5V. It's basically like this:
http://media.uxcell.com/uxcell/image...x0038_ux_c.jpg
But the factory one is even smaller - can't find a pic though.
You can get this one for $2.99, not sure on clearances but I know the iPhone factory one will.
http://www.uxcell.com/usb-power-char...ug-p-9576.html
Just plug it into our built in power inverter instead of a lighter.
Old Sep 9, 2008 | 01:08 PM
azchipka's Avatar
ORIGINAL: n0c7
Yours came with a built in power inverter??????
Old Sep 9, 2008 | 05:16 PM
ruchuck's Avatar
yeah it's weird. Some 07 and 08's came with them.
________
vaporizers
Old Sep 9, 2008 | 06:29 PM
Printerman's Avatar
Hi:
Anyone know if the built in power inverter can be added in the field...
What the cost might be ????????
Old Sep 19, 2008 | 07:53 PM
jsrd's Avatar
Printerman, today I was with dealer and the models 2008 (XLS) that are sold in Mexico have this accessory. Install OEM inversor Ac is possible, but it is necessary to verify if in our Out if the prewiring exists; of being thus, it is necessary to acquire the necessary hardware and a reprogramming to the ETACS by dealer is required. I check in my Out and have the prewired, this is what I made:
About cost, from mitsupartsman.com:
- AC plug p/n mn141360 $35.00
- console box p/n 8011a410 $30.00
- inverter under the pass seat p/n 8638a001 $325.00
Old Sep 19, 2008 | 08:47 PM
azchipka's Avatar
ORIGINAL: jsrd
What did getting the reprogramming done cost you? Anyone have the pinout for this cable so it can be fitted for use with a non-mits inverter. Any chance any one knows the amount of watts supported by the OEM one, and can you take a picture of the connection for the outgoing power lines or are those included in the port that the incoming is on. I am hoping to run two outlets one in the console and one in the rear cargo area. If the OEM inverter has enough outflow to support this I'll go the route of the OEM otherwise im going to need to go 3rd party and retro fit.
Also does the OEM still fit if the OEM amp is also installed? JSRD did you also replace your center console already, if so was the cable for the outlet already prewired as well?
Confirmation that this cable is also present on a 07' XLS
The side panel is secured with quick clips you should have no problem removing it with just your hands. Once you locate the jack you will find its secured using mits favorite securing method you guessed it more electrical tape.
Old Sep 19, 2008 | 09:14 PM
azchipka's Avatar
Moved to above post
