91 talon AWD Tsi
Old Nov 14, 2006 | 04:18 AM
  #31
racerx55's Avatar
Default RE: 91 talon AWD Tsi
ORIGINAL: TheEngineer
well its possible that it has a 95 block in it. So your saying you dont know whats wrong with it. Does it hold compression?
its got all 8 exhaust valves bent, i thought there was only 2, but 2 are bent BAD, i took them out, the guides are junk & the head is cracked around the guides, the other 6 EX. valves are bent just a little bit, all the intake valves never touched... strange... i worry about a cracked piston with how bad the 2 valves are, and the piston has a hell of a mark in it, a hit that hard can smash rod bearings too, i plan on givin it a hoan job , new rings & rod bearings, i have to get the bottom apart & see if its good enough to bother with
parts i need, rear CV axles, drive shaft, t case (soon as i count splines) crank pulley/(hamonic balancer),power steering pump, i will probly buy that head as soon as i get the extra money to spend. the guy called me and found the motor mount & some pulleys,and a boost controller he bought for it but never used.. he didnt find the plastic fender pieces yet or the wipers & cowl vent, and he says the steering pump was on top of the engine, so its probly laying on the road somewhere between his house & mine along with a handfull of bolts
i might have found a wrecked parts car thats AWD and ran good, ill know by the end of this week if he still has it , he only wanted $200 for the whole car & its a early 92 model, thats a good find if its still there
i spent way too much money in one week rebuilding the 420a for my peon race car and buying this talon, and a bunch of crap for my 450r i never ride anymore... so im gonna have to kinda put this car on hold for a few weeks. at least that gives me time to go through it all and see what all i need, im gonna go see why the fuel pump is silent when the key is turned on here shortly, i hope its a fuse or bad relay, or something simple, the oil pump rattled like hell in that motor the first few times i spun it, and took a while to get pressure, now its quiet, and i can get up to 10PSi just turning it by hand, im thinking it might been the gears chattering with air in the system after sitting for a year, this post is gettin too long ill shut up now...
Old Nov 14, 2006 | 06:10 AM
  #32
racerx55's Avatar
taking a closer look at the pistons i think i better just get another motor, theres still a really nice crosshatch in the cylinders, but look at these pics, and anyone with any kind of knowledge should be able to see it.....
i thought turbo motors had dish pistons, these look like flat tops with no dish at all to them, anyone have a pic of a stock 4g63 turbo piston so i can compare? i remember them have the number 63DT on the top of the turbo DSM motors..
looks like this is a n/a motor with a turbo on it
[IMG]local://upfiles/10240/E9C6BDFBF9B34E3A9395EE52EC981435.jpg[/IMG]
Old Nov 14, 2006 | 06:11 AM
  #33
racerx55's Avatar
damn i need to cut these down in size..
cyl 2&3
[IMG]local://upfiles/10240/5D066A0FB2264D89893B42BC8119C1CB.jpg[/IMG]
Old Nov 14, 2006 | 06:12 AM
  #34
racerx55's Avatar
[IMG]local://upfiles/10240/DC2CCB1C17BE458FA8C95E5F721DED60.jpg[/IMG]
Old Nov 14, 2006 | 06:50 AM
  #35
racerx55's Avatar
its also got a 16g turbo thats junk, its melted to hell inside, how nice, lol someone did a number on this engine
Old Nov 14, 2006 | 09:43 AM
  #36
damn that thing got destroyed. I wish i could remeber what mine looked like on my 4G63T so i could help you out
Old Nov 14, 2006 | 10:08 AM
  #37
racerx55's Avatar
yea looks like waaay too much heat, nothing looks like its been messed with for a long time, the turbo looks like you used an oxy-acetalyne torch to spin it, i should put this Holset HX40W i have on this little tiny motor & watch it explode,then buy a good 6 bolt.... probly wouldnt even have enough *** to spool it
Old Nov 14, 2006 | 10:18 AM
  #38
HAHAHA that would make for a good video. BTW where are you located
Old Nov 14, 2006 | 05:00 PM
  #39
racerx55's Avatar
NE ohio, and you?
Old Nov 14, 2006 | 06:34 PM
  #40
93eclipsegsx's Avatar
i live in berea and ESTRAW lives in strongsville
