93 eclipse front end shake
I'd say if he knows someone that has a true flat block (I can't remember what exactly they're called but they're used for determining warpage and whatnot in low tolerance applications) I'd say take the rotors off and check all 4 of them. Also check the brake calipers maybe one of them isn't working right? Check the pistons on the calipers see if they're cocking when coming out. Possibly check the bolts that hold the caliper in place? Those are the last things I can guess...
ORIGINAL: Nuggethead 420
No accidents. Tires have approx. 8,000 perelli the car is a summer car so it never sees the snow or cold.
I just dont want to buy $$$$ worth of rotors and still end up with a shake the rotors are not far out ground within .002
That should not cause the problems I am seeing. There is plenty of meat left onthe tires at least one more season.
Most places now a days won't turn rotors. At least not new rotors because the new rotors are made witha softer metal. I read an article in a magazine once about this. When they stopped using asbestos in brake pads they had to use a softer metal for the rotors to stop the squealing when you hit the brakes. So instead of turning rotors they just recommend replacing them.
We never turned rotors but then again with the safety inspections here they're pretty strict on rotor thickness and most people don't bother thinking about rotors until it's too late.
dont get me wrong i suggest he gets new ones but just to see if they are the problem here do this go to a junk yard and get a pair that look stright see if they work if the shake stops or just turn those ones.
The rotor were ground here at work. Big machine shop and it helps to be tight with the machinists, and be a former turned design engineer. So every body is focused on the rotors. Why that They are ground and run true by the indicator.
Is that they only componant on the front end? does anyone know about the bushing situation on the front or has no one ever had any problems with that in the past?
Any steering lash adjust or other variables that would cause a similar condition?
