Big Problem?? Please help
Old Jan 21, 2008 | 10:24 AM
gotitjr's Avatar
Default Big Problem?? Please help
Last night my car started missing real bad, like could hardly get past 2500 rpms, and was shaking real bad. I took a look at my injectors and on one of the the wires were loose and my timing was off real bad. I fixed both of those and it ran good. Then tonight it did it again except it is idling way rough and shaking the car. My wideband says it is really rich(at plus 25 at the 1000 setpoint on the safc, where it used to say about 12 on the wideband now is way rich). But anyway the car runs the same when i pull the #4 cylinder plug wire then put it back on, and it does the same with the #3 cylinder, But dies ifI pull the #1 or 2.[/align]
Old Jan 21, 2008 | 07:09 PM
dsm1990gsx's Avatar
Default RE: Big Problem?? Please help
What do the plugs look like? Are they fouled?
Old Jan 22, 2008 | 09:11 AM
gotitjr's Avatar
They are brand new, gapped at .032.
Old Jan 22, 2008 | 04:22 PM
dsm1990gsx's Avatar
Are you still running the stock fuel pump?
Old Jan 24, 2008 | 04:15 PM
gotitjr's Avatar
No, running a walborro 255. I'm going to do a compression test later. I will post updates.
Old Jan 24, 2008 | 04:27 PM
dsm1990gsx's Avatar
Well that could be your problem the 255 pump is over running your stock regulator.
Old Jan 24, 2008 | 06:34 PM
That wouldnt cause stumbling. I ran the GST without a FPR for a while and it was okay... really irratic fuel pressures... but okay
Old Jan 24, 2008 | 11:27 PM
gotitjr's Avatar
I do have an aftermarket fpr. But the results of the compression test are 130lbs. in cylinders 1 and 2, Maybe 7lbs. in cylinders 3 and 4. Could this be my head gasket maybe?
Old Jan 25, 2008 | 12:28 AM
My bet is something in the head. Either your timing has slipped a little, you have a problem in the valvetrain, or perhaps you could have a really badly ****ed up head gasket. However, if that was the case then you would have a ****e load of smoke coming out of the exhaust. My bet, is the timing.
Old Jan 29, 2008 | 08:47 AM
gotitjr's Avatar
