bog bog bog, feels like hitting a wall.
well, my car still seems to not be hitting redline. im out of conclusions. so my 92 gsx has intake, Exhaust, Exhaust mani, MBC, Boost gauge, redtop battery. well im still not hitting redline, if i slam the gas i get to like 4-6000 rpms n it feels like it wont go any farther, and it feels like im hitting a wall. and if i let go and restart to ease the throttle itll hit the redline and anything above that. im running 7psi and even at 9 psi it does it still. i cant seem to figure out why. is my fuel pump n injectors too small?
RE: bog bog bog, feels like hitting a wall.
check the injectors for clogging and replace them if they look shot... and you shouldnt be expierencing fuel cut off at 9psi...so check your injectors....and if all elts fails go to auto zone have them run a diagnostic on it and see if it throws any codes.....
is it free for diagnostics?
yea they hook up their computer and run it for a min and tell you if its good or not..my eclipse ran 7 codes yesterday..lol...thats what it gets for sitting for like 2 months....lol
ORIGINAL: tidus10 yea they hook up their computer and run it for a min and tell you if its good or not..my eclipse ran 7 codes yesterday..lol...thats what it gets for sitting for like 2 months....lol |
they can tell you there
i can already tell you what its gonna give. A random misfire on one or more cylinders. Your hitting fuel cut for some reason. My guess is your boost guage isnt reading right and your runnning much higher boost. I doubt its gonna be injectors. The thing that is common is for the fuel filter to need to be replaced. It could even be a bad fuel map sensor.
ORIGINAL: TheEngineer i can already tell you what its gonna give. A random misfire on one or more cylinders. Your hitting fuel cut for some reason. My guess is your boost guage isnt reading right and your runnning much higher boost. I doubt its gonna be injectors. The thing that is common is for the fuel filter to need to be replaced. It could even be a bad fuel map sensor. well uhh.. arnt you just a book of information..... |
ORIGINAL: TheEngineer i can already tell you what its gonna give. A random misfire on one or more cylinders. Your hitting fuel cut for some reason. My guess is your boost guage isnt reading right and your runnning much higher boost. I doubt its gonna be injectors. The thing that is common is for the fuel filter to need to be replaced. It could even be a bad fuel map sensor. how hard is it to fix and find the sensor? and how much is the sensor? |
ORIGINAL: BrunoBoy650 ORIGINAL: TheEngineer i can already tell you what its gonna give. A random misfire on one or more cylinders. Your hitting fuel cut for some reason. My guess is your boost guage isnt reading right and your runnning much higher boost. I doubt its gonna be injectors. The thing that is common is for the fuel filter to need to be replaced. It could even be a bad fuel map sensor. how hard is it to fix and find the sensor? and how much is the sensor? |
