compresion test
Old Oct 19, 2007 | 08:12 PM
superhumankiddy's Avatar
Default compresion test
Hey, I was wondering, what is the took called to do a compresion test. And also, how hard is it to do, and how do you do it? Thanks.
Old Oct 20, 2007 | 05:42 PM
93eclipsegsx's Avatar
Default RE: compresion test
well its called a compression tester, i believe you take out one spark plug, insert the tester, and let the crank turn 3 times and read the reading, and then to so for the othere.
Old Oct 20, 2007 | 06:14 PM
I can get one at any auto parts store right? and do I turn the crank by hand, or key?
Old Oct 21, 2007 | 12:48 PM
auto parts store should have one, take all the spark plug wires off and then take a sprak plug out and install the tester and crank the car. you can use the key. just let it turn over a couple times.
Old Oct 21, 2007 | 05:15 PM
Nubiebubie_GSX's Avatar
You should disconnect the cam sensor since it the easiest thing to do and accessible. That way the ecu wont send spark or fuel. But will still crank. Or you can disconnect the coil pack and the fuel injection fuse. I just disconnect cam to keep it simple. Crank your car till you get a stable reading.
Old Oct 21, 2007 | 06:39 PM
Thanks for the info guys. What should it read?
Old Oct 23, 2007 | 06:55 AM
this has all been discussed and is on the faq's. But here is the link to how to perform it and what compression you should be getting
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
EMonz57
Jun 4, 2008 09:55 PM
F.O.G.
Jan 21, 2008 07:49 PM
ryant25bb
Oct 12, 2006 12:54 PM
lelliott
Feb 25, 2004 11:29 AM
