Driving light quesitons
Old Oct 7, 2007 | 06:06 PM
mikeginob's Avatar
Default Driving light quesitons
The driving lights on my 93 have never worked since I bought it in May. Thought I would see if I could get them working this weekend. It had a blown driving light fuse so I knew I had a short somewhere. I found the short and repaired it. My problem now is that with the headlights on low beam and I push the driving light button on the dashthe driving lights willonly stay ON as long as I keep the button depressed. As soon as I remove my finger the driving lights go out. I tried swapping equivalent relays and that did not help. I'm running out of things to check....
[ul][*]Is the button on the dash supposed to stay pushed in when depressed? Maybe I have a bad switch?[*]Does anyone have a wiring diagram?[*]Any other suggestions......[/ul]
Thanks,
Mike
Old Oct 8, 2007 | 01:06 PM
WhiteMonster!'s Avatar
Default RE: Driving light quesitons
HA that sucks.
you can tape it for now lol
maybe try buying a new button or something...you can probably get one at a junkyard for a few bucks
Old Oct 8, 2007 | 03:54 PM
mikeginob's Avatar
I have a Haynes manual with wiring diagrams in the back but I can find the fog light circuit. It is hard to trouble shoot if you don't know exactly how it is supposed to function. Does the button remain depressed or does it pop up?
Old Oct 9, 2007 | 12:52 AM
Well my fog light button doesnt stay depressed either.
You push it in and then when you let go the fog lights turn off again.
I dont see what messing with wires would do but im not an elecrician either lol
I dont c why any1 needs fog lights anyway but i really think if you push the button in and it pops back up then its a "bad button" and you just need to pop 1 in there! and hey if it doesnt work...a button @ a junkyard is lik a few bucks!
Old Oct 14, 2007 | 01:16 PM
superhumankiddy's Avatar
I don't know if you have figured it out yet or not, but there is a write up about how to fix this problem on http://vfaq.com/mods/1g_foglight_switch.htmlif your problem is the same as I think.
Old Oct 14, 2007 | 11:16 PM
nick_200321's Avatar
i have the same problem with mine, i push the button and they turn on but when i let go they turn off, i think superhumankiddy pinpointed it..
Old Oct 15, 2007 | 09:48 AM
That site has a whole lot of info, I've used it a few times. It's great to put as your fav.
Old Oct 24, 2007 | 04:19 PM
mikeginob's Avatar
Thanks for the link superhumankiddy! I had several problems with mine first the power wire inside the fog light was shorting causing the fuse to blow and then thebutton would not stay depressed. I fixed the short and got a used switch and everything is working correctly now.
Thanks,
Mike
AW-100
Feb 22, 2014 12:56 PM
keith 1
Oct 4, 2008 03:06 PM
FlyinPanda
Nov 19, 2007 10:58 PM
lpprest
Oct 31, 2005 03:16 AM
Yargk
Sep 14, 2003 06:42 AM
