E-Brake
Old Sep 16, 2007 | 07:51 PM
nick_200321's Avatar
Default E-Brake
How do i tighten my E-Brake?? i have to pull it way up in order for it to engage all the way, i wanted to see if i could tighten it to make it kick in sooner.. if it is easy to do lol
Old Sep 16, 2007 | 08:03 PM
Default RE: E-Brake
i cant see it being too difficult. Ive never had to do it but check out the ebrake by taking off the interior. You should be able to figure it out from there. If that doesnt do it then check out the caliper at the other end there may be a problem there
Old Sep 16, 2007 | 09:16 PM
Default RE: E-Brake
i dont understand what you are saying, taking off the interior?? like removing the center consol or what?
Old Sep 17, 2007 | 12:17 AM
Default RE: E-Brake
Removing the side kick panels should reveal a cable mechanism. Simply loosen the bolt with the cable attached... and pull the cable with your hand till its a little tighter... then re tighten the bolt and your done
Old Sep 17, 2007 | 06:01 AM
Default RE: E-Brake
well i am a noob when it comes to interior work, but do you have a pic i can possibley see so i can see what side kick panels your talking about?? thanks
Old Sep 17, 2007 | 06:45 AM
Default RE: E-Brake
when in the drivers seat it is the panel on the side of your leg. and the same goes for the passengerside. The parts that attach to the center console where your shifter is. It would probably be easier to just remove the center console to get to it
Old Sep 17, 2007 | 10:39 AM
BC31059's Avatar
Default RE: E-Brake
You might also want to check your rear brake pads, not saying that they are bad but worn down, as they get thinner you have to pull back more on the E-Brake to get them to engage, I had a similar issue and found that the brake pads were close to worn out, after installing new brake pads the E-brake was back to the normal position when being engaged.
Old Sep 17, 2007 | 02:58 PM
Default RE: E-Brake
aight guys thanks, i think it might be what BC31059 said now that you brought it to my attention, my pads are pretty worn. ill check out both things, thanks
92diamante
Oct 30, 2004 08:23 AM
92diamante
Sep 9, 2004 09:00 PM
Ace2133
Sep 7, 2004 10:44 PM
dolfans
May 19, 2004 12:14 AM
Jacoby
Nov 12, 2003 11:14 AM
