ECU
Old Aug 12, 2007 | 11:43 AM
SILVER's Avatar
Default RE: ECU
mmmmmmmmm, thats weard!
Old Aug 12, 2007 | 03:49 PM
superhumankiddy's Avatar
Default RE: ECU
yeah, I know, tell me about it. This car is a whole lot of trouble, but I love it, so it's worth it.
Old Aug 18, 2007 | 10:02 AM
1987 TSI's Avatar
Default RE: ECU
you probably not the same problem ECU you had. From what I have found out the capacitors are notorous for going bad in those ECU. As a matter a fact I have been having the same problem. Either the ECU should have the capacitor changed in it or a remanufactured ECU will have modern parts in it.
Now, I have a Question, I replaced my ECU and now the car runs but I still have no fire to cylinders 2 and 3. (which is probably what you are experiencing when you say "like the mass in unplugged.) I have new coil packs on as well. Crank/cam sensor is functioning. ignition module maybe? Any ideas?
sorry to highjack
Old Aug 18, 2007 | 12:28 PM
Default RE: ECU
I unplugged the MAS and the running changed a lot, so I take back it acting like the MAS is unplugged. When at idle it idles like it normaly does, but when I'm driving and I'm going slow with the RPMs at around 3 to 4000, it kinda slightly jurks back and forth, well not jurk. It's hard to explain. I do plain on having my ECUrebuilt, so I'll see what that does. Thanks
Old Oct 27, 2008 | 11:43 PM
brycesworld's Avatar
Default RE: ECU
Mine is doing the same thing? What did you do to fix it?
Thanks
Bryce
Old Oct 28, 2008 | 12:30 PM
dsm1990gsx's Avatar
Default RE: ECU
ORIGINAL: brycesworld
Thanks
Bryce
Check the dates before you post.
Old Oct 28, 2008 | 08:13 PM
Default RE: ECU
ORIGINAL: dsm1990gsx
Thanks
Bryce
I did, however being that I am having the same exact issue and couldn't find it anywhere else in the forum I decided to ask the person who might be able to help me since they were in the same boat.
Maybe you should try leaving useful advice when you post. Or at least answering the question that was asked instead of butting into a conversation that does not concern you. Thanks.
Old Oct 28, 2008 | 08:16 PM
dsm1990gsx's Avatar
Default RE: ECU
Thanks
Bryce
Or you could start a new topic w/ your concern and it makes it easier for people here to solve your problem. I wasnt trying to bea dick just trying to help a newb.
nyc95gst
Jan 18, 2008 01:25 PM
oldmansgs
Apr 14, 2004 07:39 PM
EclipseUK
Mar 27, 2004 06:51 PM
DarkrealmX
Mar 14, 2004 01:55 PM
i_r_eddie
Feb 24, 2004 01:24 PM
