engine swap
Old Mar 11, 2007 | 06:52 PM
MikeJ's Avatar
Default engine swap
I'm new to this board and the tuner cars. But here goes.. My son and I bought a 94 eclipse with a blown up 1.8 na 5sp trans 2wd. my ?? is, he totaled out a 93 talon 2.0 na 5sp 2wd. and I'm wondering 1) is this a possible swap? and if it is possible any advice would be greatly appreciated.. I'm not new to swapping engines however this will be my first front wheel drive swap.
Thanks Mike
Sorry to be a bother if this question gets asked alot
Old Mar 11, 2007 | 11:20 PM
nick_200321's Avatar
Default RE: engine swap
yes this is a very possible swap. the 90-94 eclipse,laser,and talon all run on basically the same motor. keep in mind it will be difficult. im not sure how hard if the new engine also wont have turbo though..i have a 92 eclipse 1.8 and i was told not to do the swap because its expensive but if you already have the other motor i dont see why not. also im not sure if you could use the 1.8l tranny you might have to change it..it might not be strong enough
Old Mar 12, 2007 | 05:06 AM
5Tizzle's Avatar
It actually depends. is the 2.0 a chrysler 420a, or a non turbo mitsubishi 4g63?
If the motor in the totaled car is a chrysler motor, it should swap right over, but if its the mitsubishi, its not possible.
Old Mar 12, 2007 | 09:00 AM
MikeJ's Avatar
How do I identify the engine I have ? The valve cover says 16 valve dohc. Is that enough info ?
Mike
Old Mar 12, 2007 | 11:05 AM
silvercoupe97's Avatar
Well, the 1.8L is a good indication that you have a 4g37. That's the only 1.8L motor that came with the 1Gs.
Here's a 4g37.
Old Mar 12, 2007 | 11:20 AM
ORIGINAL: Jeffisdecentttttt
ummm 420a's didnt come in the 1g's
Its definetly something that has been done, and can be. Your gonna need the the engine and tranny out of the 2.0L and the ECU. While your at it i would use all the wiring too. It will just make it alot easier in the long run
Old Mar 12, 2007 | 07:49 PM
MikeJ's Avatar
Ok thanks for the info.. I can use the tranny and wiring harness & ecm out of the eagle
Now next question what is the trick to getting them out. ie together, seperate, out the top or drop out the bottom ?
Again Thanks
Mike
Old Mar 12, 2007 | 07:52 PM
well out the top with a cherry picker if you can get one. Or i have known people to pull an engine with three people. But id imagine that to be a PITA. But you cant drop it, you have to have it dome out from the top
Old Mar 12, 2007 | 08:41 PM
MikeJ's Avatar
ok out the top it will be i've been out in the garage looking at it and it appears they will come out together ok.. also I will have to use the eagle harness the 4g63 in it has more hook ups than the 1.8 had. alot more work than i wanted to do but I figure this way maybe my son will appreciate this car a little more and were spending time together. I'll keep ya posted on how it goes.
Thanks Again
Mike
Old Mar 12, 2007 | 09:54 PM
oh wait a sec. I misread your post a bit. I thought it just said how to get the engine out. You can drop the tranny down first and then lift the block out the top. That would be a posibility. I think you can pull them together too. So i guess its up to you
rstoevo
Jan 20, 2013 10:47 AM
kiwii29
Jul 31, 2009 01:18 AM
greg999
Dec 1, 2003 10:49 PM
mekka
Oct 17, 2003 07:51 PM
tristanlee85
Jul 2, 2003 01:29 AM
