fuel pump
ok, im trying to put my walboro 255 fuel pump in and my book says i have to unscrew the fuel line so i can get the old pump out, and ive tried for like an hour or just trying to gwt it out. is there anything that i can use to get it off or just break it and get a new piece?
I agree with Talon. But as for disconnecting the old pump you might want a pair of gator grips or robo grips might help. Also spray it thoroughly with penetrating oil let it soak in might help a bit too.
awww man...
The fuel pump pushes the fuel out of the pump and through the line to the fuel filter, after that its pushed through the fuel pressure regulator which has a diaphram that regulates the amount of fuel that can reach the injectors, then the extra fuel is shot down the return line back to the tank.
