fuel pump relay
Old Feb 28, 2006 | 11:35 PM
nstriglia's Avatar
Default fuel pump relay
can anybody tell me where the fuel pump relay is located on a 1992 Eclipse GS. fuel pump does not activate when the key is turned on but will run if hot wired. Thanks in advance
Old Mar 1, 2006 | 03:27 AM
Sanguinius's Avatar
Default RE: fuel pump relay
If noone beats me to it I'll check for you in my book tommorrow. But you can start by checking the relays under the hood should be by one of your strut towers and check in the fuse box. They should be labeled.
Old Mar 1, 2006 | 03:28 AM
Sanguinius's Avatar
(And YES it's cuz it's 1:30 A.M. and I'm too lazy to put the laptop down, get outta bed and go get the damn book LOL... )
Old Mar 2, 2006 | 02:44 AM
My93EclipseGS's Avatar
Ok found where the relay is. And you are going to love this. It is located on the passenger side (though it might be on the driver side can't tell by the pic in Haynes) of the center console inside the car. You will have to remole the side panel for the console to get access for it. If you engine is a 2.0 it will be a 10 pin connector. otherwise its a 8 pin connector. Recommend you get the Haynes Manual for your car. The Procedures for testing the relay are on pages 4-3 thru 4-5. Good luck
Old Mar 2, 2006 | 05:48 AM
Sanguinius's Avatar
Wow damn never would have thought it to be THERE...
Old Mar 2, 2006 | 01:33 PM
Me Either, It took some looking last night to find it. I thought it would have been on the firewall somewhere. Thats an engineer for ya. put it in a spot where you least likely to look LOL. BTW if you need to know what to look for once you pull the relay let my know and I can post the procedure here. Let me know what type engine though I don't feel like typing out both LOL.
JStrateger
Sep 11, 2008 11:59 PM
blumaverick
Jun 8, 2007 05:19 PM
kenny
Aug 11, 2006 12:42 AM
mpwizard
Jun 25, 2006 03:23 PM
audionxs
Sep 19, 2003 11:56 PM
