gas tank leak
is there anything other than the sending unit assembly that could leak on the top of the fuel tank?
i only gtet a gas smell when i launch it hard or make a hard right corner,& only over 1/2 tank,and the top of the tank is damp, but not around the sending unit, i already pulled that out and resealed it twice. im assuming my tank has a hole in it unless theres maybe a retarded fitting for the vent or something.[&:]
the thought crossed my mind, here i go workin on the f-ng thing more than driving it again.
now where in the hell do i find a gas tank for a 93 AWD...
i suppose ill pull the tank out tomorrow cuz i cant find the leak, maybe ill dry it out good and let it sit for a week then weld it shut.
the good part is it dont leak bad enough that it even drips off and the sides of the tank wont even get wet, its just a little on the top in front of the sending unit. if that cover isnt over the hole it reeks like hell inside the car though.
cuz the top of the tank is wet genious. and it only leaks whens its over 1/2 tank and i launch it or make a hard right corner. you want to come look for yourself?
im just wondering if anything elses has a seal into the tank (return line or vent) other than the sending unit assembly.
