Holy F*** boost leak from hell
Old Jan 5, 2007 | 08:44 AM
racerx55's Avatar
Default Holy F*** boost leak from hell
So my car started running crappy again, hitting fuel cut at 14 psi. I do the boost leak test again and had all 4 injectors leaking badly, throttle body shaft seals, both connections on the IC, BOV gasket, boost guage line connection, throttle body gasket, the hose to the BOV had a pinhole and the FPR hose had a small pinhole. 3 weeks ago it was 100% sealed up. ... justbitching to myself here thats all[8D]
Also is my TurboXs boost controller (0-30psi) supposed to bleed off air? i thought they just restricted to the WG actuator.
Old Jan 5, 2007 | 05:21 PM
Default RE: Holy F*** boost leak from hell
I did a write up in the DIY section on the shaft seals for the throtte body. The injectors are common too
TheAdvocate
Mar 3, 2008 11:34 AM
BrunoBoy650
Feb 14, 2007 03:31 PM
EMonz57
Jan 30, 2007 02:08 PM
ictponder
Jul 15, 2006 02:59 AM
TheAdvocate
Sep 6, 2005 01:36 AM
