How much $$$ for motor rebuild
Old May 25, 2006 | 01:24 PM
WhiteTrash93's Avatar
Default How much $$$ for motor rebuild
Hey everyone, how much would it cost me to have the motor rebuilt in my 93 Eclipse it has the 4g63, I want a little more power but I dont to go nuts it is my DD. I dont have mad money to do this but I do want it done right. Any places in my area I could take it to, I live right outside of Philly in PA. Thanks in advance everyone.
Old May 25, 2006 | 01:30 PM
eclipsed4u's Avatar
Default RE: How much $$$ for motor rebuild
anywhere from $1,000-$10,000 depending on parts and labor costs.
Old May 25, 2006 | 01:35 PM
slow420a's Avatar
Stock rebuild expect 1500-2500 in parts and labor. Try to contac conceptillusions.com, their in pa and do extensive motor work.
Old May 25, 2006 | 05:35 PM
RCJr9186's Avatar
if you are only looking for more power just strap a turbo onto it, the 4g63 can take up to 13lbs on stock internals.
Old May 25, 2006 | 06:47 PM
nYOfas's Avatar
I dont even want to think about the money to rebuild...hell no....
Old May 26, 2006 | 12:00 AM
eclipsed4u's Avatar
ORIGINAL: RCJr9186
the internals can handle ALOT more than that. its the fuel system that maxes out first.
Old May 26, 2006 | 12:23 AM
RCJr9186's Avatar
i thought the block could only handle up to 13 lbs, then after you bore/forge it you were good up to like 23 lbs on stock head...
Old May 26, 2006 | 12:41 AM
Evil1993Eagle's Avatar
You can get a used non turbo jdm engine off ebay for like $500.00. I know its not a rebuild, but it will have low miles and wont go too deep into your pocket.
Jnz tuning, they do it all, (215) 997-6850 ask for josh or eric. They are located in Lansdale, maybe 15 min from norristown.
Old May 26, 2006 | 10:44 AM
ORIGINAL: RCJr9186
No the block is fine for high boost. I think you could at least go up to 20psi without a problem. The first problem with high boost comes in around 15 psi when the stock turbo (t25) starts to become inefficient, then the next thing like eclipsed4u said is the fuel system (hitting fuel cut) but the bottom end can handle far more.
Old May 26, 2006 | 10:48 AM
well going back to the topic. I know a place where you can get the full rebuild kit for $215. Not totally sure how much a place will charge to do it though. But if you can find a place than i can show your where to get this...unless you find the kit cheaper that is
