idling problem on a 1g
Old Dec 23, 2005 | 02:25 AM
Reddragon06's Avatar
Default idling problem on a 1g
my 91 gs has an idling problem it jumps up and down from 2 to 1500 rpms. and ive replaced it with 3 different sensors so what else could make it do this.
Old Dec 23, 2005 | 02:29 AM
1997gsteclipse's Avatar
Default RE: idling problem on a 1g
check for vacuum leaks that would be a real good start to finding the problem. Maybe even plugs and wires.
Old Dec 23, 2005 | 02:41 AM
vacuum test on what, i was going to change the spark plugs but ran out of money... lol
Old Dec 23, 2005 | 03:05 AM
Joel_CA's Avatar
It could just be that your adjustments are off or that you are adjusting it incorrectly. Remember, there's a CTP switch that needs to be adjusted BEFORE adjusting the TPS. From there you can adjust your idle base settings.
Joel, CA
Old Dec 23, 2005 | 09:52 AM
1990GSX's Avatar
also check your altanator belt, mine slips when it's loose and runs bad.
Old Dec 23, 2005 | 12:22 PM
georgegsx's Avatar
do u have an aftermarket bov?
Old Dec 23, 2005 | 12:24 PM
georgegsx's Avatar
my bad ist a gs nevermind
Old Dec 23, 2005 | 01:04 PM
Sanguinius's Avatar
Does it run rough or does it sound like it's hunting? (Like someone is revving the engine up and down)
Old Dec 23, 2005 | 01:10 PM
DSMTalonAWD51's Avatar
you have idle surge. tell us what youve tried to replace to far. Possibilities are a bad isc motor, idle adjustment is off, bad egr, dirty tb, missing/bad vacuume line. no matter what it is, it will be located around the tb
Old Dec 23, 2005 | 01:30 PM
Sanguinius's Avatar
ISC? I'm guessing you mean IAC motor? That was what I was thinking it is...
