idling problem on a 1g
Old Dec 23, 2005 | 02:14 PM
92_laser's Avatar
Default RE: idling problem on a 1g
I would also check the timing... on my car the timing some how got really far advanced and ran like $h!t
Old Dec 23, 2005 | 08:35 PM
Joel_CA's Avatar
Early models used an actual motor actuator to physically move the throttle plate open or closed as a means of adjusting idle- It was called an ISC/MPS or Idle Speed Controller with a Motor Position Sensor. If the setting of the MPS is off- it can cause idle hunting as if someone was stepping on the throttle and letting it go. I have seen many instances where someone turned a screw here or touched an adjustment there throwing EVERYTHING off. It may not need a single thing at this time- it may just need to be adjusted PROPERLY.
Later models used an IAC to control idle with basically allows a controlled amount of air to bypass a fully closed throttle plate.
Joel, CA
Old Dec 23, 2005 | 09:53 PM
Sanguinius's Avatar
Ah O.K. I didn't know they used the ISC on the 1g's my bad.
Old Dec 24, 2005 | 08:00 PM
Joel_CA's Avatar
Not ALL 1G's used the ISC setup- my 93 DOHC has a IAC but i'm not exactly sure what year they started with it.
Joel, CA
Old Dec 24, 2005 | 11:51 PM
Sanguinius's Avatar
I'll browse around through a few books I have and see if I can find something that tells what year and what engine they started the IAC with.
metalmtb
Nov 9, 2021 11:00 PM
Big Daddy J
Apr 17, 2010 01:47 PM
k_kay
Mar 26, 2010 06:43 AM
austinw23
Apr 24, 2007 07:57 PM
KillerEclipse
Jul 7, 2006 02:04 AM
