just got a 1990 eclipse today
Old Nov 21, 2006 | 12:02 AM
1990GS's Avatar
Default just got a 1990 eclipse today
well just got a 1990 eclipse today for $600 only has 89k on motor so if anyone could give me any specs or info about the 1990GS that would be great
[IMG]local://upfiles/10397/39DC852B7FB24B90AFDFFE09BF1CEB6A.jpg[/IMG]
Old Nov 21, 2006 | 12:03 AM
93eclipsegsx's Avatar
Default RE: just got a 1990 eclipse today
well what kind of info do you want? i mean its just a broad question.
Old Nov 21, 2006 | 12:08 AM
1990GS's Avatar
motor specs, 1/4mile times, 0-60 times
Old Nov 21, 2006 | 12:18 AM
well its a 2.0l I-4 DOHC 135hp engine. i ran a 17.1 with my 90 gs 5-speed. not sure on the 0-60 times.
Old Nov 21, 2006 | 01:12 AM
1990GS's Avatar
guess not to bad, now to ask will this car last me till like 150k?
Old Nov 21, 2006 | 01:17 AM
it will easily last you till 150k as long as you do simple maintenace. But my question is, is it a turbo model because i know that in the 1g eclipse's sometimes the GS was a turbo model. In which case the car is gonna be faster than woody spec'd
Old Nov 21, 2006 | 01:25 AM
1990GS's Avatar
nope not a trubo i wish it was tho.
Old Nov 21, 2006 | 01:46 AM
Sanguinius's Avatar
First off you can't go by the 1/4 times listed in mags or even on dealer charts and whatnot. Times are almost as reliant on you as a driver as they are the specs of the car itself. Also your times will be affected by what's been done to the car previously. Was it beat to **** or babbied?
As for lasting... You're at 90K miles right now correct? CHANGE YOR TIMING BELT NOW!!! Timing belt's are supposed to be changed around 80-90K miles. I've seen them run till 110 and whatnot but don't risk it in this car. Also you paid $600 for it and JUST got the car. Change the air filter, fuel filter, and get the oil changed. Maybe even an oil system cleaner would be a good idea. With proper care and maintenance ANY car will last WELL into the 100 of thousands of miles. I worked for a shop where a '99 Neon was a regular customer and it had over 300K miles on the car. Ran like a top (Except for the problems caused by accidents it was a driving school's student vehicle). So that should say SOMETHING for regular maintenance.
Old Nov 21, 2006 | 02:04 AM
I think the Mitsu Tbelt is recommended at 60k actually? maybe that is just newer mitsus but still
Old Nov 21, 2006 | 02:08 AM
Sanguinius's Avatar
Could be but either way 80 is a good time to replace it if it can't be proven that it was done already. If she runs still then let's keep her there.
