missfire on hard excell
i run Nology wires on my DSM n always have.yeah they cost more than MSD and other but ive noticed the biggest gains from them. but also dont go cheap on plugs then i stand bhind NGK. for NGK the higher the number the colder the pluga 7 or 8 works fine. now as for ignition boxes you really dont need them but every lil helps i run the MSD DIS 2 6212 but you really dont need somthing that big. MSD has the DIS 2 6211. its a very very nice box n will handle anything you can think of.
to be on the safe side id change the fuel filter also if it hasnt been done in awhile.i hope you stay away from using fuel aditives cause they cause more probs than they save. if you can find a local performance store get a few gallons of 100 n add that to your 93 that will help flush your systum
ok, think I'll just get the fuel filter changed when I get my oil changed next time. I have no idea when anything was changed or anything mostly about the car, and I have only had it for a few months, so I'm kinda starting from scratch. everyone keeps saying check for boost leaks, question on that. should it hold a level of boost while running? or drop down below zero when off the gas?
ORIGINAL: 1990GSX
I still think it is the plugs\Wires I honestly would do that before you change a fuel filter
a boost leak doesnt always show on the boost gauge. a bad one you will know but small ones can be a pain. for example my stock Plastic BOV leaks after 16 PSI so when I spool up I hit 19 and by red line I am at 16. but when I cracked my BOV (I dropped it on the ground like a putz) I knew it was leaking but the gauge showed no syptoms of it other than the lack of power when at full boost. I mean if felt like going from 19 PSI to 10 PSI it was bad lol
it sounds like hes got a 1g so the BOV is fine as is im sure just make sure you use good ol mobil 1 when you change your oil the dude that had my GS-T before me used crapoline n when i tore it down it had WAY more wear on the rings n walls then it should have for the kinda driven that was done.
ORIGINAL: domestickilla
