need help upgrading motor
Old Aug 16, 2008 | 05:42 PM
dsm1990gsx's Avatar
Default RE: need help upgrading motor
ORIGINAL: needsagst98
if u do all that to that motor u can easlily crank out 350hp.
How doesforged internals give you more horsepower? The stock bottom end is good for over 400 hp. Your wasting you time building a motor for 250 hp.
Old Aug 19, 2008 | 01:03 AM
mack29730's Avatar
this is the first eclipse i have built i know that the 6 bolt is the best and got this car for free for family member if the bottom will hold (which the honda f22 wont) i'll leave the bottom alone and replace the bearings and seals i have a innercooler and oil cooler also i haven't bought the header due to don't know what turbo is good for the hp power so if i go 300hp. i have the head in the shop getting the works (stage IV). i know i have seen on here that the stock injectors re not enough for the stock turbo when turned up i want to push between 18 to 20 pounds to it if possable. i hearalot of people say the evo16 turbo what is good for the upgrades the guy at the head shop said that with the head alone i'll get a 15% horse power increase. i was thinking the walbro 255lph and 750 injectors and also upgrade the fuel rail
Old Aug 19, 2008 | 06:42 AM
yea if he had it all built it would be able to get 500hp. You can get 350 on a stock bottom end
Old Aug 19, 2008 | 07:27 PM
mack29730's Avatar
ok cool save me a lot of money that why so the evo 16g is ita good choice in turbos? also the fuel upgrade i was thinking on useing is that too much or not enough?
Old Aug 19, 2008 | 07:28 PM
dsm1990gsx's Avatar
If your running 750 injectors your gonna want to look into dsmlink and your also gonna need an afpr to control the 255 pump.
BrianWSNC
Aug 12, 2008 09:11 PM
leedesert
4th Generation
Apr 29, 2007 01:39 PM
chickenbird
Jan 2, 2006 05:33 PM
antomx
Dec 4, 2004 02:57 AM
SMOKENYOU
Feb 14, 2003 06:24 PM
