no vacuum
Old Sep 10, 2007 | 10:13 AM
93eclipsegsx's Avatar
Default no vacuum
assuming its bad, my car has 0 vacuum, ive tapped into all kinds of vac lines to make sure i had 0, wel i do. is it because my cams? hks 272's or is maybe timing off.
Old Sep 10, 2007 | 10:19 AM
Default RE: no vacuum
its your boost guage thats telling you?
Old Sep 10, 2007 | 10:22 AM
yes my boost gauge is saying no vac, but when i rev it it will build a couple psi so i know its reading something.
Old Sep 10, 2007 | 10:50 AM
it has to be the guage. I cant see you having zero vaccuum.
Old Sep 10, 2007 | 11:27 AM
Your car would run like *** with 0 vac.
Either a leak or there is something wrong with your gauge. Try connecting another.
Old Sep 10, 2007 | 10:06 PM
estraw's Avatar
wooody u sure your vacuummhose isnt pinched behind the steering wheel? remember how you had it set up if you have the wheel up or w/e it pinches it, im sure that would affect what it reads
Old Sep 11, 2007 | 01:33 PM
no its not bc we took out mikes gauge and hooked it up tp the same spot and there was still no vaacuum, oh well ill try another place and see if it works.
Old Sep 11, 2007 | 03:36 PM
estraw's Avatar
well ya but if there was a kink in the line then it would not read vacuumm on any guage. check the lines the whole way through the fire wall and see if there are any kinks in it
Old Sep 11, 2007 | 09:35 PM
no we took out mikes gauge that was in his car and kooked it up outside of the car with a different line.
Old Sep 11, 2007 | 09:40 PM
Kaede.Noir's Avatar
no vacuum? wouldnt that mean a loose manifold? no gaskets somewhere, or nonfunctional valves?
