ok now im pissed
i have searched all through the internet and i cannot get this car to go into gear.. i have adjuseted the adjusment rod that leades to the master cylinder like i was told to on a website with no prevail.. i have bled the system many many times to be sure of no air, but still nothing.. we just pulled off the tranny because i was told the pressure plate might be too tight so we pulled it and used a torque wrench set to 15ft/lbs like the haynes book i have says.. still wont go into gear...
it is like with the clutch to the floor it is still grabbing, but yet it wont shift.. we started it in gear once and all it did was burn up clutch and try to stall but my step dad gave it gas and kept it running it was just burning clutch...any help??
sorry for the long post, but i was going into detail so maybe you guys can help me... im justreally pissed right now, i have tried everything, it just wont work
1Gs have issues with the clutch pedal and needs to be replaced as needed and then have the pedal welded to the rod.
Here's a fix from Tuner's.
http://www.dsmtuners.com/forums/show...G+clutch+pedal
another
Just fill in the asterisks with the site name and your golden.
another
