Problem with my 91 Eagle Talo
Old Oct 1, 2006 | 09:32 PM
iamabadperson777's Avatar
Default Problem with my 91 Eagle Talo
i tried starting it today and i cant put it into gear. i can start it in gear just cant shift or nothing. i noticed that there wasnt any pressure on the clutch pedal as near as much as there was 4 days ago. anyone know what my problem is and how i can fix it?
Old Oct 1, 2006 | 09:37 PM
estraw's Avatar
Default RE: Problem with my 91 Eagle Talo
when you start it in gear, does the car jerk forward??
air in the system or manky fluid.
To eleminate the possibility of air... simply remove the master cyl reservior cap... and pump the clutch pedal for a long time to get all thge bubbles out.
If that dont work then you need to drain the whole system... and flush it clean... that means draining it mroe than once.
Im 99% sure that one of those is the answer to ur prob
Old Oct 1, 2006 | 11:45 PM
estraw: ya it does jerk forward a little.
sebba: thanks i will try those.
Old Oct 2, 2006 | 12:51 AM
estraw's Avatar
it could be that your clutch release system is leaking somewhere, i know ive gone over this before, try doing a search on it
Old Oct 2, 2006 | 02:04 AM
alright thanks guys, ill try those and let you know if any of them worked.
w_houle
Nov 15, 2007 06:47 AM
bsmooth99
Feb 22, 2005 02:22 PM
colinwolfe
Jun 12, 2004 04:31 AM
2fast4u
Sep 6, 2003 06:44 PM
shane82786
Jul 2, 2003 01:17 AM
