removing balance shafts
Old Aug 22, 2008 | 04:32 PM
mack29730's Avatar
Default removing balance shafts
i seen on another forum that you can remove the balance shaft and take weight out of the motor. what is the down side of this i was thinking if removed i would onlt have the timing belt to worry about.
Old Aug 23, 2008 | 09:51 AM
dsm1990gsx's Avatar
Default RE: removing balance shafts
The only down side is a sight vibration which isn't noticeable at all. My last 3 dsm's had them removed and would suggest anyone to do it.
Old Aug 23, 2008 | 11:50 AM
mack29730's Avatar
when you remove them you don't have to put the belt on pulleys right?
Old Aug 23, 2008 | 07:28 PM
dsm1990gsx's Avatar
It depends, read the write up on www.vfaq.comstep for step and you'll answeryour question.
Old Aug 23, 2008 | 09:00 PM
mack29730's Avatar
thanks i see how everything works and off to the dealership to see if i can get the parts ordered.
Old Aug 23, 2008 | 11:10 PM
The dealership doesn't offer that.
Old Aug 24, 2008 | 03:27 AM
mack29730's Avatar
the vfaq had the part numbers for the dealership but have seen the kit on ebay the differents is the shaft design the shaft on the vfaq show has a grove in it and the one on ebay don't.
Old Aug 24, 2008 | 09:36 AM
dsm1990gsx's Avatar
ORIGINAL: Sebba
Its not"kit" you buy from the dealer, the vfaq gives you part numbers that you can use.
Never buy b/s removal kits off ebay thats a big no no.
Old Aug 24, 2008 | 03:51 PM
mack29730's Avatar
ok i have the part numbers off the web site was going to order those in the morning when they open. seen were Sebba said the dealership didn't offer it but i have the numbers for the dealership.i did see two kits on ebay but was going to ask first before getting something not good. the one was the parts from the dealership and the other had a different shaft.
Old Aug 24, 2008 | 07:49 PM
there are other places you can buy the removal kits from. Like buschur racing makes a kit here
https://secure.buschurracing.com/cat...496230c83f9fa8
Also dsmparts has a decent kit
http://www.dsmparts.com/customer/pro...138&page=1
also SBR
http://www.slowboyracing.com/estore/...p;bestseller=Y
and AMS
http://www.amsperformance.com/store/...roducts_id=221
so there are other places that are better than ebay, but also cheaper i bet then going to the dealership.
