removing balance shafts
Old Aug 24, 2008 | 10:53 PM
Default RE: removing balance shafts
The dealer offers a BS removal kit?.... SERIOUS?
Old Aug 25, 2008 | 08:00 AM
^^no its not a kit, all it is, you have to buy all 4 parts separately, (plate, 2 bearings, and stub shaft)
Old Aug 25, 2008 | 12:43 PM
mitsupartsman.com's Avatar
you only need three parts (md092785 cap,md098626 plug,and mf665543 sealin bearing) these parts are used in the 4g61 engine.
1992 mirage with 1.6 dohc no balance shafts were used in that engine. parts will cost $25.00 send me an email.
Old Aug 25, 2008 | 08:26 PM
well you need (2) of the sealin bearings correct? So you need 4 total parts
Old Aug 26, 2008 | 07:19 AM
no just one bearing. oil travels into the front of the balance shaft and out the back. when you block off the front oil channel and remove
the balance shaft you have infact disabled the oiling to the rear bearing............
Old Aug 28, 2008 | 03:28 AM
mack29730's Avatar
i order the parts the vfaq 2 bearing seals 1 shaft and plug $30 with the DSM club discount.
Old Aug 28, 2008 | 06:40 AM
you got a good deal, let me know how the removal goes.
good luck
Old Aug 29, 2008 | 05:20 PM
mack29730's Avatar
it was a little agervating but easy to do i still have motor in car if you follow the vfaq forum and it goes good it just getting the motor to drop down far enought to pull the shaft out.
Old Aug 29, 2008 | 06:52 PM
dsm1990gsx's Avatar
You can leave the front shaft in since the engine is still in the car.
Old Aug 31, 2008 | 02:19 PM
mack29730's Avatar
the vfaq had both ways to do it out of car and in car. i wanted the weight out and the way they have you drop the motor down really low just make sure you don't let it slip off and check all you vac lines.
