Rim specifications
Old May 23, 2009 | 04:30 PM
lillben07's Avatar
Question Rim specifications
I have a 91 Eclipse GS with miss-matched rims right now. Last summer I did a swap to the dual piston brake calipers from a 2G GSX on the front. Due to the larger calipers, I needed to have different rims on the front since the stock 205/55/R16 Eclipse rims that I had didn't clear the calipers. So, I wound up putting stock 205/55/R16 rims from the '97-'98 Dodge Avenger that I had laying around since they have the same bolt pattern and cleared the calipers. I'm looking at getting new rims soon so that I can actually rotate my tires, but I can not seem to find the specs for the Avenger rims. I want to make sure that the new ones I get have the same off-set so that there will be no problems with clearance. Does anybody happen to know the specs of those rims or those from a 2G GSX, since those obviously are big enough to clear the calipers? I really need some help here... Thanks!!
Catch22!
Nov 24, 2007 01:16 AM
brianef
Apr 20, 2007 08:00 AM
DrAgOnBoY45479
Dec 19, 2004 11:16 PM
vertstanggt
Dec 3, 2004 01:21 PM
nate5023
Aug 22, 2004 01:17 PM
