Stalling???
Old Jul 17, 2006 | 12:04 PM
WhiteTrash93's Avatar
Default Stalling???
Hey everyone I put in a K&N air filter yestarday and my car started stalling when I would come to a stop unless I stayed on the gas a little so I turned the idle up a little, could the filter cause this?? And did I screw anything up by turning the idle up a little?? Any help would be great.....thanks in advance...C Ya[sm=icon_rock.gif]
Old Jul 17, 2006 | 12:44 PM
Default RE: Stalling???
the most common problem when an intake is put on is the MAS not being hooked up correctly. Make sure everything got tightned correcty and that all the wires were plugged in
Old Jul 17, 2006 | 12:45 PM
Reset the car... dissconnect the neg battery terminal for an hour
Old Jul 17, 2006 | 07:28 PM
Its not an intake thou Its just a K&N air filter and I am running it opened without the box on but I did that with the stock air filter too and stalling problems, I will try resetting it tonight I will let you know how it went...thanks everyone
Old Jul 17, 2006 | 08:16 PM
either that or you have an air leak
Old Jul 17, 2006 | 09:31 PM
ORIGINAL: Sebba
How can find out if I do have an air leak?
Old Jul 17, 2006 | 10:44 PM
tidus10's Avatar
ORIGINAL: WhiteTrash93
your too cocky.... i had the same problem.. like he said disconnect your battery for like 5 min and if the problem persists adjust your idle some....thats what i had to do now my car idles at factory 850rpm....
Old Jul 17, 2006 | 11:01 PM
ORIGINAL: tidus10
Im too cocky??? Why do you say that I aint trying to be if I am...sorry
Old Jul 18, 2006 | 09:53 AM
ugh! Did it work?
Old Jul 18, 2006 | 11:41 AM
I adjusted the idle and now its fine, when I am in P or N it idles @ 1000 but it idles @ around 850 when sitting in gear with the brakes on. Thanks for all the help everyone, I dont know where I would be without this site, probably forking out lots of funds to some mechanic...LoL I am gonna do the valve cover tonight, then I will be replacing the head next to fix the oil burning problem so you will be seeing more from me in the future...[sm=icon_rock.gif]
