starts then stalls
Old Feb 25, 2006 | 02:21 PM
jrflax19's Avatar
Default starts then stalls
I have a '93 GS and everytime I start it up, it will stall right out.. I have to hold the gas pedal down for a little bit and hold the RPM's up around 2000.. Then once I let off the gas pedal, the RPM's drop down like it is going to stall again, but raise back up to around 1000-1300.. What do you think this could be?
Old Feb 25, 2006 | 03:23 PM
93eclipsegsx's Avatar
Default RE: starts then stalls
i dont know if it matters but is it an auto? because ive been looking online and reading up on it so i can answer your question.
Old Feb 25, 2006 | 04:24 PM
Sanguinius's Avatar
Sounds like you may need to adjust the BISS. Is it hunting at all (Runs up to XK Rpm drops to Xk RPM then bounces back and forth)? If so it might also be the IAC motor.
Old Feb 25, 2006 | 05:03 PM
jrflax19's Avatar
It's a 5 speed.. What is the BISS, and the IAC motor? It doesn't bounce back and forth between RPM's.. it will just start then stall right out, unless I hold the gas, and hold it around 2000.. then as I ease off it drops all the way down to around 500, and then goes back to about 1000-1300.. and holds there and idles..
brandoN^gsT's Avatar
Adjust the BISS screw, and then take it in for a full tune up. That should take care of it. If not, Sang may be right, if it continues to hunt, you'll need a new IAC motor. But, try a full tune up first. The will, more than likely, take care of the problem.
-brandoN^-
Old Feb 25, 2006 | 05:08 PM
Sanguinius's Avatar
Nah it's the BISS (Base Idle Set Screw?) . What he describes doesn't sound like hunting. Hunting would be constantly up and down like it can't find the RPM it likes to sit at. BISS would kill it until it warmed up and if it's off enough it'll kill it even after warmup.
Old Feb 25, 2006 | 05:35 PM
jrflax19's Avatar
where can I find the BISS on this car.. It is the 1.8L SOHC.. and do I turn it clockwise or counter-clockwise? thanks
Old Feb 26, 2006 | 04:28 PM
its on top of the throttle body and not to sure which way to turn it
licanstik
Aug 14, 2014 04:15 PM
carguard
Jun 23, 2008 05:27 PM
Bigfatso
Aug 17, 2007 04:56 PM
embryriddledude
Jul 11, 2006 09:37 AM
muddyjoe
Jul 9, 2005 10:54 PM
