Testing ECU and Dist.
Hello everyone from a new guy. I'm having an issue with a '92 GS 1.8 5 spd and I know that someone on here can help me. I'm a regular on some some other forums (BMW and Corvair) so I know how valuable these things are. Anyway, I've been around cars all my life (I'm 45) and am even pretty good with OBD systems but I'm pretty clueless on Mitsu. So my friend's car died on her the other day, the classic "driving along and it quit". Here's what I've done and know:
IGN fuse is ok
Timing belt is intact and turning
Red lead to the coil (I think) has power
ECU non-responsive
No obvious burning or leaking caps in the ECU
Questions:
I'm using an improvised light bulb assembly to retrieve codes since I just moved and can't find my meters. Any reason that wouldn't work?
Is there a way to test the ECU and distributor/coil/CAS assembly so I can avoid throwing expensive parts at it?
I browsed a Haynes manual but the section on engine sensors seems to favor the 2.0 and has little info testing the 1.8 dizzy.
This and other forums have been a great help (i.e. the leaking capacitors thing) but much searching hasn't answered my specific questions. Any help is greatly appreciated to get this poor girl back on the road.
Allen
IGN fuse is ok
ECU non-responsive
Questions:
Allen
Well problem solved. A used ECU from the yard didn't do the trick but a used dizzy did. I'll assume it was the CAS or coil and be happy with $43. Thanks for all the help guys, I really appreciate it. If y'all ever need help with a Corvair or BMW E21, look me up.
MrJayDeeOne
Jun 28, 2006 10:42 PM
