throwout berring???
Old Apr 10, 2007 | 10:44 AM
nick_200321's Avatar
Default throwout berring???
I have a 1992 eclipse with a 1.8l engine..its a 5 speed and i just got it running. i have only drove it a few times and noticed it is sometimes hard to shift into 1st gear. i have the transmission off so i can replace the seals because it was leaking and i wanted to know, could the throwout berring make it hard to shift into 1st gear if its bad??
any information would be helpfull
thank you
Old Apr 10, 2007 | 11:21 AM
Default RE: throwout berring???
i would think it should have a problem in all gears if it was the TOB. Also you would notice a noise when your driving from the tranny. More of a squeel type noise, if it was the TOB. Im thinking it might be a 1st gear syncro. or you might just need to change your fluids or something. Also while you have the tranny off i would check the normal stuff like the slave cylinder and master cylinder
Old Apr 10, 2007 | 12:19 PM
Patrick's Avatar
Administrator
i agree...that last car that i dealt with that had a bad TOB made a sort of "chirping" noise...
Old Apr 10, 2007 | 06:58 PM
in response to what TheEngineer said, it wouldnt be the cylinder or master cylider because i belive the guy who had it before me replace them both when he put in a stage 1 racing clutch. it might have been the fact of low fluids though due to the tranny leak..thanks for the help...if you get more ideas please let me know.
metalnepal
Aug 8, 2009 07:52 AM
jstylez
Apr 20, 2007 05:15 AM
brina22maree
Nov 1, 2005 03:12 PM
