tranny bolts
Old Sep 19, 2007 | 08:24 PM
jason clipse's Avatar
Default tranny bolts
on my tsi...how many are there? and is the little 12mm bolt on the opposite side of the tranny under the starter part of the bolts that are holding it to the engine???? a diagram will help and im going to buy a repair manual tommrow
Old Sep 20, 2007 | 07:53 AM
Default RE: tranny bolts
[sm=icon_rtfm.gif]
Haha, just messin. Im not sure how many bolts but once you have the piping and everything out of the way its pretty apparent what bolts hold it in. Is this an AWD? i cant remember. Also the manual will definetly have a better picture than we can give you
Old Sep 20, 2007 | 07:54 AM
I dont see why you couldnt just look?
Old Sep 20, 2007 | 08:16 AM
estraw's Avatar
heres a quick and easy way to tell if there are more bolts holding it on. if you think you have them all off, try to seperate the trans from the engine, if it seperates, theyre all off, if not, you prolly forgot onelol. i dont thing there are any bolts that bolt on the opposite side, unless you can tell it goes through the block into the bell housing. otherwise they should all be on the one side of the bell housing
Old Sep 20, 2007 | 09:19 AM
i did look/ take a bunch of them off and yes its an AWD and i can see it separating on one side but im not sure about the back side...and i can barely feel the bolt let alone see it to see if it goes thru the block. It feels like it does.....i was kinda askin towards the guys that have the 1g AWD's cause most of them have built the motor.
Old Sep 20, 2007 | 12:36 PM
estraw's Avatar
ive helped my friend tear apart his 1g gsx and rebuild it over the last 2 years if that counts for anything.
where does it feel like its catching up at?
Old Dec 15, 2007 | 11:05 PM
gotitjr's Avatar
there is one right above the transfer case, but you cant get to it unless the transfer case is off
Old Dec 16, 2007 | 08:48 AM
dsm1990gsx's Avatar
ORIGINAL: jason clipse
There are like 7 or 8 and the 12mm bolt under the starter has to come off too, its a little tricky b/c u cant really see it.
And since its awd take the t/c off, it'll make it easier to see everything.
Old Jan 14, 2008 | 09:39 PM
racerx55's Avatar
dott
Jul 11, 2005 12:14 AM
Defiler
May 11, 2005 08:26 PM
Defiler
May 9, 2005 07:36 PM
GARYMITSU
Mar 21, 2005 09:12 AM
92montero007
Sep 27, 2004 01:38 AM
