trans replacement
Old Jan 14, 2008 | 04:40 PM
tailwhip's Avatar
Default trans replacement
Hi all, newbee here. I need to know if a M/T from a 94 GST FWD will work on a 91 2.0 non turboFWD. It's hard to find a m/t for this car, the awd and 1.8 m/t's are abundant.
Any help is appreciated.
Old Jan 14, 2008 | 05:07 PM
Default RE: trans replacement
im pretty sure you cant
Old Jan 14, 2008 | 07:41 PM
dsm1990gsx's Avatar
It'll fit, the 1.8 and 2.0 n/t use the same trans.
Old Jan 14, 2008 | 09:30 PM
racerx55's Avatar
theyre all interchangeable, other than 90 transmission - wich work but have slightly different shift levers on them.
you can use AWD trans in a NT fwd is the center diff is welded...
Old Jan 16, 2008 | 03:21 PM
dsm1990gsx's Avatar
ORIGINAL: racerx55
The diff on a90 is the shifter calbes, shifter and the bracket on the trans. The trans its self is the same.
Another thing if you were to use a awd/fwd turbo trans the flywheels are different from the non turbo trans.
Old Mar 29, 2009 | 08:08 AM
staarekitsune's Avatar
Hey if you are still looking for a non turbo m/t tranny I have one from a GS, which from my understanding is what you are looking for.
Old Mar 29, 2009 | 10:13 AM
dsm1990gsx's Avatar
Check the dates before you post.
Old Apr 18, 2009 | 09:37 PM
lillben07's Avatar
Default Trans Replacement
You can use the transmission from a 94 GST. The engines have the same block, so it will bolt right up. Make sure that you get the right transmission though. I just went through a whole fiasco with replacing a transmission for my 91 GS. The SOHC uses a F5M22 transmission while the DOHC and Turbo eclipses use a F5M33 transmission. The difference between the two is that Mitsu built up the F5M33 to handle the extra power put out by the GST. The F5M22 will work, but there's now way to tell how well it's going to hold up, depending on how many miles it has on it. If you have any more questions, feel free to send me a PM. good luck with your car.
soambah
Jun 30, 2004 09:27 PM
madmat
May 21, 2004 01:45 AM
Mums Taxi
May 10, 2004 11:59 PM
sal111
Jan 12, 2004 08:43 PM
vtf-1
Jun 15, 2003 05:50 PM
