tune?
so i bought this car from a friend and im almost positive that there is nothing mechanically wrong with it. all it needs is a tune since it has bigger cams and injectors in it and so on. how do i go about doin this or getting this done? i know about dsmlink but if i do it myself im scared to mess something up.
thanks list of everything in it: DNP Tubular Manifold Bullseye T04B 60 Turbo 2nd Gen Maf Setup Turbo Back Exhaust Front Mount Intercooler Greddy Type S Blowoff Valve Walboro 255 Fuel Pump Injector Clinic 750 cc (injector) Aeromotive Fuel Pressure Regulator Innovative Motorsprots Wideband w/Gauge Apexi AFC NEO 90 Big Rods ACL Pistons ARP Head Studs Balance Shaft Removed New Showdown Motorsports Head New Brian Crower 272 Cams New Head Gasket New timing belt Fluidamper Harmonic Balancer New water pump Fresh plugs and wires |
I know dsmlink is very user friendly, I use other stuff to tune w/ b/c I'm poor.
so you dont think i bought a dsm link and tuned it myself i wouldnt really mess anything up? im not planning on tuning it to max performance or anything.
You'll be fine. You could always get an eprom ecu send it out and have it chipped to your mods.
how would i go about doin that? what exactly would i have to do for that anyways?
ughh idk what all that means....like the 1G ECMLink v3 Package with ECU
1G DSM or the 1G ECMLink v3 Package with Non-EPROM Conversion 1G DSM. which one would i need? |
Do you have an eprom ecu?
idk im pretty sure its stock. i dont know what eprom is...
Some 1g ecu's came w/ eprom chips from the factory. The only way to find out is to remove the ecu and pop the cover off and look for the chip.
| All times are GMT -5. The time now is 06:02 AM. |
