whats next?
Old Jan 7, 2006 | 02:14 PM
93eclipsegsx's Avatar
Default whats next?
ok i have a 93 gsx and im wondering what i should do next?
here's the list of what i have done so far.
evo III 16g turbo
turbo back exhaust w/out the cat
intake
walbro 255 fuel pump
greddy turbo timer
Old Jan 7, 2006 | 02:40 PM
eclipsed4u's Avatar
Default RE: whats next?
injectors and SAFC/Emanage
how much boost are you running?
Old Jan 7, 2006 | 03:48 PM
Sanguinius's Avatar
I agree with eclipsed. Injectors, fuel filter, SAFC, possibly the SMIC/FMIC (Depending which you have you may want to switch to the other who knows).
Old Jan 7, 2006 | 04:06 PM
DSMTalonAWD51's Avatar
if you dont have a boost controller, id get one, then a frontmount, a stronger clutch, then id go with an safc/bigger injectors
Old Jan 7, 2006 | 04:33 PM
sorry i forgot. i have a boost controller that i still have to put in and i have a boost gauge. i dont know the exact number of boost im running because i havent really ripped on it. but i would say 15 pounds.
Old Jan 7, 2006 | 05:09 PM
what kind of injectors should i get?
Old Jan 7, 2006 | 06:36 PM
estraw's Avatar
hey 93gsx, how'd that custom fit turbo timer fit in your car???
Old Jan 7, 2006 | 09:22 PM
it fits really good, still gotta lean forward a little bit to see it but it fits nice and snug.
Old Jan 7, 2006 | 09:23 PM
also would getting an A'PEXi Super AFC II be a good choice.
Old Jan 7, 2006 | 10:48 PM
Joel_CA's Avatar
You can try a shart shifter (sorry old joke- some of you may get it) . Seriously, roller bearings at the end of the shift cables (roller blade bearings) as well as shifter base bushing (found on Ebay) can do alot to tighten up the shifter in the Gen 1 Eclipse. I've got a set on my 93 and am simply amazed at how crisp and positive each gear engagement is. It's a very cheap mod and is well worth it. Good Luck!
Joel, CA
