A\C System Engine Throw Codes
Old Jun 14, 2006 | 03:30 PM
Dragonslayer's Avatar
Default A\C System Engine Throw Codes
Hey guys, what engine codes could be thrown with the a\c to a 1999 mitsubishi eclipse rs? Due to my car a\c works but it is not really cold thinking it might be the compressor not turning on.
Old Jun 14, 2006 | 03:41 PM
Default RE: A\C System Engine Throw Codes
These are the OBDII engine codes pertaining to an A/C system
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
Is your check engine light on? If it is then just go to autozone or something and have them run the code
Old Jun 14, 2006 | 07:40 PM
XTREME's Avatar
If you pop the hood while the car is running and listen to the compressor you should be able to hear it switch on. Of course somebody else will have to press the A/C button. If the compressor turns on then you might have a leak in the A/C system somewhere.
Old Jun 15, 2006 | 02:59 PM
where is the a\c compressor relay located in with a 420a engine? Also, if it is the compressor not turning on, should i replace the relay or do i know that i have to get another compressor?
Davie-h
Nov 11, 2013 01:25 PM
membreya
Apr 18, 2013 12:50 AM
minping
Jan 6, 2005 09:53 AM
Prototype_fabs
Aug 15, 2004 03:27 AM
Prototype_fabs
Mar 22, 2004 01:41 AM
