10psi? WTF????
Old Sep 7, 2006 | 09:23 PM
paintballproam's Avatar
Default RE: 10psi? WTF????
i tried my bov all the way soft, then hard, then in the middle, nothing changed
Old Sep 7, 2006 | 11:14 PM
so ummm, what should i check for leaking? i went over my IC pipes and my vacume lines and it looks good
Old Sep 8, 2006 | 01:11 AM
you checked at the intercooler right, because i know that is a place that has problems alot. And like dixons said, it might be a wastegate issue as well.
Old Sep 8, 2006 | 07:45 AM
Its normal for the the stock turbo (T25) to drop some at the high end.
Old Sep 8, 2006 | 10:15 AM
idk about dropping down to 10 psi though
Old Sep 8, 2006 | 09:37 PM
i do
Old Sep 9, 2006 | 02:32 PM
well i went through and checked all the vacume lines, tightened and checked all the IC pipes. I test drove it and nothing changed. Do i need a new turbo
Old Sep 9, 2006 | 09:29 PM
You dont actually need a new turbo... thats just how the stock T-25 behaves. It will drop upto 10psi in the top end...
Take off your intake and see if you can wiggle the shaft... if you cant then your ok... if you can then you have shaft play and need a new turbo...
The T-TooSmall living upto its name
brandoN^gsT
Feb 19, 2006 01:07 PM
Seth
Jun 29, 2004 10:09 PM
thewilltolive
Apr 28, 2004 12:12 PM
toaster_power
Mar 8, 2004 05:00 PM
hellraiser
Feb 13, 2004 11:25 AM
