16 or 17" rims?
Old Aug 2, 2005 | 08:03 PM
mags750's Avatar
Default 16 or 17" rims?
97 RS 420a stock suspension about to undergo a sport set-up suspension 1-1.25' lowering/springs/shocks/bars/strut bars ect.
Can I put 17' rims on or should I stick to the 16's?
Old Aug 3, 2005 | 12:43 AM
DSMTalonAWD51's Avatar
Default RE: 16 or 17" rims?
17s would be fine. Its all preference though, your car will probably be a little slower with them, and unles you get the right size tires your speedometer will be a bit off too.
Old Aug 3, 2005 | 10:06 AM
get435's Avatar
the place that installs the tires should be able to fix the speedo problem.
Old Aug 3, 2005 | 02:19 PM
wicked_outlander's Avatar
a light 17' s would be fine...but you have to sacrifice your accellaration.
Old Aug 3, 2005 | 08:11 PM
mags750's Avatar
Thanks for the replies everyone.
I really don't like the fact that perf will be hurt/or acceleration. Is this due to the larger diameter or the weight of the wheels. If just the weight I think I'll keep them under 20lbs....
Old Aug 4, 2005 | 01:31 AM
weight makes a big difference but its rotational inertia thats affecting performance, which means its quite possible that a heavy set of small rims will be better performance wise than a light set of large rims. either way 16 to 17 inch rims wont make much a difference, but if you went any bigger than that not only is your car gonna be slower, but its gonna look gay. i guess im just picky when it comes to rims, but 18's look retarded on eclipses, and so do anything chrome.
Old Aug 4, 2005 | 10:14 AM
get435's Avatar
LMAO! dude the rims you saw were all wrong i think a set of 18" rims with rubber bands on them fit just right. crome rims do look like **** some times but the right set of them make any painted or toned rim look like ****.
Old Aug 5, 2005 | 09:54 PM
ORIGINAL: DSMTalonAWD51
lolz...got it right!!! i, dont like 18's too. ( 18's good for mini s.u.v.'s)
gvwalker
4th Generation
Jun 13, 2008 07:10 AM
enzo_hashmat2006
Aug 7, 2006 06:45 PM
l33th41
Sep 6, 2003 08:51 PM
Twotone
Aug 8, 2003 08:44 PM
tom57
Aug 3, 2003 12:37 PM
