16gggggggg
First off do a little searching on the forum and you'll find multiple threads with ALL the info you need. But a quick rundown:
Injectors
Fuel pump
Tubro timer
Boost guage
Boost controler
the turbo itself
intake and exhaust
Fuel pressure regulator
Blow off valve
Engine internals (Higher boost #'s like the 20-22 PSI you're talking abot will DESTROY you stock internals)
Then you want to start thinking of things like the cooling system and the intercooler and associated piping.
I think this is a damn good start for items you'll need to replace. Anyone else have anything further to add?
Injectors
Fuel pump
Tubro timer
Boost guage
Boost controler
the turbo itself
intake and exhaust
Blow off valve
Turbo timer is not nessesary and neither is a motor build up "yet". the 16G will only get him around 350WHP give or take and the bottom end will hold 400+ before being to much. but everything else is a good idea to have. And you couldnt have searched to hard for these answers because Player69 alone has at least 4 threads about the 16g that asked a similar question and a few more details
![Wink](https://mitsubishiforum.com/forum/images/smilies/wink.gif)
Good call Pete I didn't even think of the clutch... I also thought the 16G was about the time you wanted to start thinking about a full engine rebuild... And my bad I forgot the piggyback fuel system... I had most of it though...
The 16g is a great upgrade for the 4g63 in the respect that its a bit better then the t25 and is a direct fit. When you go with a 60 trim then its time for a rebuild.
Thats really not cool though, the 4g63's stock internals can take up to two times the hp that it comes with where the 420a blows apart after an extra 60hp. I am going to fight chrysler.
ORIGINAL: slow420a
I would say fmic, bov, 3' dp, 3' cat back, intake, 3"gm maf w/ translator, 190lph walbro, safc, boost gauge, wideband(or soemthing similar for tuning), mbc, and a clutch.
