16gggggggg
Old Feb 27, 2006 | 01:37 AM
5Tizzle's Avatar
Default 16gggggggg
I did use search for this, but didnt find anything helpful.
To run about 22 psi, what all am i going to need if i upgrade to a 16G in my 95 TSi? Its totally stock btw.
Old Feb 27, 2006 | 05:40 AM
Sanguinius's Avatar
Default RE: 16gggggggg
First off do a little searching on the forum and you'll find multiple threads with ALL the info you need. But a quick rundown:
Injectors
Fuel pump
Tubro timer
Boost guage
Boost controler
the turbo itself
intake and exhaust
Fuel pressure regulator
Blow off valve
Engine internals (Higher boost #'s like the 20-22 PSI you're talking abot will DESTROY you stock internals)
Then you want to start thinking of things like the cooling system and the intercooler and associated piping.
I think this is a damn good start for items you'll need to replace. Anyone else have anything further to add?
Old Feb 27, 2006 | 09:05 AM
NESpeed's Avatar
Don't for get a fuel management , either a piggy back or stand alone.
Old Feb 27, 2006 | 09:09 AM
Turbo timer is not nessesary and neither is a motor build up "yet". the 16G will only get him around 350WHP give or take and the bottom end will hold 400+ before being to much. but everything else is a good idea to have. And you couldnt have searched to hard for these answers because Player69 alone has at least 4 threads about the 16g that asked a similar question and a few more details
Old Feb 27, 2006 | 12:30 PM
slow420a's Avatar
I would say fmic, bov, 3' dp, 3' cat back, intake, 3"gm maf w/ translator, 190lph walbro, safc, boost gauge, wideband(or soemthing similar for tuning), mbc, and a clutch.
Old Feb 27, 2006 | 02:18 PM
Sanguinius's Avatar
Good call Pete I didn't even think of the clutch... I also thought the 16G was about the time you wanted to start thinking about a full engine rebuild... And my bad I forgot the piggyback fuel system... I had most of it though...
Old Feb 27, 2006 | 04:48 PM
slow420a's Avatar
The 16g is a great upgrade for the 4g63 in the respect that its a bit better then the t25 and is a direct fit. When you go with a 60 trim then its time for a rebuild.
Thats really not cool though, the 4g63's stock internals can take up to two times the hp that it comes with where the 420a blows apart after an extra 60hp. I am going to fight chrysler.
Old Feb 27, 2006 | 11:00 PM
DSMTalonAWD51's Avatar
ORIGINAL: slow420a
id agree with this but dont exactly need the maft, add 660 injectors and knowledge of how to tune or some $$ to pay someone to tune and youre all set
Old Feb 28, 2006 | 12:20 AM
slow420a's Avatar
Ya i wasent sure about the maft either, I know for 1g's a good upgrade is a 2g maft but i didnt know how far that would actually take the car so I threw it in there to be sure.
