18's or 19's on a 2g eclipse
Old Oct 30, 2005 | 08:39 PM
frakinstine's Avatar
Default 18's or 19's on a 2g eclipse
Whats up guy's have any of you ran 19's on you eclipse and if so how low was your car?
Old Oct 30, 2005 | 08:48 PM
Lil red's Avatar
Default RE: 18's or 19's on a 2g eclipse
if you run the correct tires for the extra rim size it would be the same height....
Old Oct 31, 2005 | 10:00 AM
rims wont lower the car, if the car isnt lowered rims will make it stand funny. 19s will fit but they are really really bug for a 2G IMO 18s whould be the way to go
Old Oct 31, 2005 | 01:20 PM
shreff99's Avatar
I have a set of 18x8 inch (I think) wheels for my '99 Eclipse GS-T but not on it yet cuz I need tires...my problem is knowing the right size of tire that will fit it without rubbing anywhere when I lower mine...I am either going with 205/40/18's or 215/35/18's, I think I'll be safe with either of those....what does anyone else think?
Old Oct 31, 2005 | 03:11 PM
slow420a's Avatar
The abslout biggest our cars can take with out having any problems are 224x18x40, Anyhting bigger and the rear fenders need to be rolled. Also if you go that big the car cant be lowered more than an inch the bach wheels will rub agenst the assymebly.
Old Oct 31, 2005 | 07:32 PM
shreff99's Avatar
Thanks dude...I was kinda thinkin that too and was also thinkin not lowering my ride no more than an inch for the same reason and that clears it up for me a little better, what is gonna suck is that I have coil overs to go on it and that's what I'll be using to lower it...Not too excited about the ride those are gonna give me....I have a friend who has a '97 Spyder GS-T that is lowered and he put a set of 18 inch wheels with 225/40/18's on it just a couple of weeks ago and his tires rub like a mo' fo' and he was pissed about it....This is coming from a kid that put a Big 16G turbo in place of the factory turbo in his Spyder but didn't do **** else to it performance wise other than a 2 1/2 inch cat-back and maybe an intake but expected to get a ton of power and performance out of it and was pissed cuz he hasn't...Then he tells me that it isn't worth putting a bigger turbo on LOL...Duhhhhh...Not the sharpest pencil in the box at times [8D]
Old Oct 31, 2005 | 07:38 PM
eclipsed4u's Avatar
ORIGINAL: shreff99
he is a ricer :lol:
Old Oct 31, 2005 | 08:20 PM
MORRISSEY's Avatar
my ride is lowered with only a two finger gap, i have 18 inch konig imagines, using 225 40 18 and have had no problems rubbing at all.
Old Oct 31, 2005 | 08:35 PM
My GS was lowered 1.5inches and I had 18s 225/40/18 with no rubbing at all and I also had my BFG comp T\A drag radials that were 235/65/15 with a 15 inch race rim and had only minimal rubbing up front with those.
Old Oct 31, 2005 | 10:53 PM
slow420a's Avatar
ORIGINAL: MORRISSEY
The approxmiate rod hight of a 2g is 2 3/4 inches... how tall are two finger put togather...
ORIGINAL: EMonz57
The 3g's have more room under the wheel well. Most rim/tire combos for the 2g's are 18x205x40 where for the 3g's are 18x225x40. For the record if you lower a 2g on stock shocks more than an inch and a half the shocks are useless.
