1999 Convertible Eclipse GS 2.4L dies
166k miles Automatic New timing belt New crank pulley New crank position sensor New crank shaft seal New cam shaft seal New oil pump New oil pump seal New water pump New valve cover gasket New NGK stark plugs New Spark Plug Wires Car runs/drives for about 5-10 minutes and than dies ..than after 5 minutes waiting... once you start again ...same thing ..it dies after about 5-10 minutes...and you have to repeat this over and again... Where could be problem? could it be transmission or something related to engine temperature ? |
