1999 Eclipse GS Windows Leak
My eclipse has been broken into twice recently, both passenger and driver windows have been replaced. Before all of this I could go to the auto carwash without water spirting through the top of the seal, after the new windows were installed it leaks real bad. The window installation people can't seem to adjust them to where they don't leak, anyone had this problem or have asuugestion on how to solve it ?
Sounds like they are using a thiner glass so it is not snugin the top seal like oem glass. also there is adjustments inside the door it will take 2 people to adjust it there should be 4 bolts at the top when the window is rolled up what you can do it loosen them have the other person push on the botom of the window than tighten them this will fix it most of the time.
TheRock0720
Nov 12, 2010 12:30 PM
