1st gen eclipse 4g63t engine?
Hey guys im still considering getting a 95-99 gst/gsx. crank walk was keeping me from gettin this car but i was just on jdm-online and they have the 91-94 4g63 turbo engines for $1495.
That doesnt seem toooo bad to replace the engine if crank walk were to take place. Has anyone had any experience with www.jdm-online.com ? And if crank walk were to come is the engine the only part which would be affected?
Thanks,
Thanks,
agreed. Just as long as maintenance is kept up your not gonna have a problem. And they is way to much money for a 4g63. You can get used blocks for alot cheaper on dsmtrader.
ORIGINAL: Rob
If you're that scared (which you shouldn't be) get a 6 bolt engine out of a 90-92.5 dsm. Problem solved. Crankwalk is overated anyways.
Thanks,
ORIGINAL: TheEngineer
Thanks,
Yea using good oil and keeping up on changes is the best thing. Also the reason from crankwalk (IMO) is that you put extra pressure on the bearings at low oil pressure points, which means while your at idle and at start up with the clutch depressed. So avoid keeping the clutch depressed when comming to a stop. Just drop it to nuetral. Also you can disable the clutch start switch so you dont have to have the clutch depressed to start the car.
Hey guys,
I just went to dsm graveyard and they have 6 bolt blocks for $800. Is the block all i would need? And if so how much am i lookin at to swap all the other stuff and get it in the car and running?
Thanks,
Thanks,
