1st gen eclipse 4g63t engine?
Old Jan 13, 2008 | 02:42 PM
hawwk11's Avatar
Default 1st gen eclipse 4g63t engine?
Hey guys im still considering getting a 95-99 gst/gsx. crank walk was keeping me from gettin this car but i was just on jdm-online and they have the 91-94 4g63 turbo engines for $1495.
That doesnt seem toooo bad to replace the engine if crank walk were to take place. Has anyone had any experience with www.jdm-online.com ? And if crank walk were to come is the engine the only part which would be affected?
Thanks,
Old Jan 13, 2008 | 02:44 PM
Rob's Avatar
Rob
Default RE: 1st gen eclipse 4g63t engine?
If you're that scared (which you shouldn't be) get a 6 bolt engine out of a 90-92.5 dsm. Problem solved. Crankwalk is overated anyways.
Old Jan 13, 2008 | 02:47 PM
agreed. Just as long as maintenance is kept up your not gonna have a problem. And they is way to much money for a 4g63. You can get used blocks for alot cheaper on dsmtrader.
Old Jan 13, 2008 | 02:48 PM
hawwk11's Avatar
ORIGINAL: Rob
Thanks, rob... My cousin told me about the over rated part too, but i wasnt sure. 90-92.5 are the only ones that have six bolt?? I thought it was all 1st gens. up to 94?
Thanks,
Old Jan 13, 2008 | 02:50 PM
nope only 90-92.5 After that they got a 7 bolt (basically when chryler and mitsubishi ended the DSM agreement)
Old Jan 13, 2008 | 02:53 PM
hawwk11's Avatar
ORIGINAL: TheEngineer
Wow this sound great, i thought c-walk was something that was just like almost guaranteed in a way. When you say keep up on main. is that like the basics like oil, and fluid changes?
Thanks,
Old Jan 13, 2008 | 02:54 PM
hawwk11's Avatar
Thanks,
Old Jan 13, 2008 | 02:58 PM
Yea using good oil and keeping up on changes is the best thing. Also the reason from crankwalk (IMO) is that you put extra pressure on the bearings at low oil pressure points, which means while your at idle and at start up with the clutch depressed. So avoid keeping the clutch depressed when comming to a stop. Just drop it to nuetral. Also you can disable the clutch start switch so you dont have to have the clutch depressed to start the car.
Old Jan 13, 2008 | 03:00 PM
hawwk11's Avatar
Very interesting. Thanks, for all the help and tips.
Old Jan 13, 2008 | 03:37 PM
hawwk11's Avatar
Hey guys,
I just went to dsm graveyard and they have 6 bolt blocks for $800. Is the block all i would need? And if so how much am i lookin at to swap all the other stuff and get it in the car and running?
Thanks,
