2g aftermarket radio grounding
Old Apr 29, 2007 | 06:04 PM
I Drive Naked's Avatar
Default 2g aftermarket radio grounding
Bought a new stereo for my car.
Kinda stumped on the best place to ground it.
I was thinking the shift cable bracket, but idk.
help!
Old Apr 29, 2007 | 08:30 PM
antlip's Avatar
Default RE: 2g aftermarket radio grounding
If your talking about a head unit you ground it to the stock ground wire that the stock head unit hooks up to.
Old Apr 29, 2007 | 08:58 PM
The plug-in harness/adapter I bought for it does not have a ground hook up.
It has all the power, speaker channels, and illumination.
Radio has all that, and a black ground wire.
Old Apr 29, 2007 | 09:40 PM
jlh077464's Avatar
There should be a ground wire from your stock head unit. Unless your talking about an amp?
Old Apr 30, 2007 | 12:49 PM
RCJr9186's Avatar
dude just find a solid metal place to ground it and, ground it. mine was grounded to the metal casing that makes up the dash but rerouted it to under my seat w/ my 2 amps and just grounded all 3 to the chasis.
Old Apr 30, 2007 | 12:55 PM
Dusty Eclipse's Avatar
In the 2g, look at the 2DIN hole... now look at the top left in the back there... theres a bolt. Loosen it a little... now,crimp an eye loop onto the end of your black (ground) wire... put the eye loop onto that bolt and twist it back in.
Old Apr 30, 2007 | 03:29 PM
Kaede.Noir's Avatar
if you took out the whole console pannel (which i had to do XD) there are some bolts near the shifter (well, the auto at least...) they provide good ground, if not just use a tester light hooked up to the hot wire and search away
Old Apr 30, 2007 | 03:38 PM
I grounded it to a piece of metal in the dash and it works just fine. lol
Old Apr 30, 2007 | 03:46 PM
Neg battery terminal? The struts?
Old Apr 30, 2007 | 04:40 PM
The finished product.
