2g bov
Old Aug 13, 2008 | 10:59 PM
needsagst98's Avatar
Default 2g bov
is it really common that a 2g bov would leak after 14 psi on the stock t25? cause i peak boost at 14 and run 13 normal. i cant get any higher then that. everything else is hooked up right too.
Old Aug 13, 2008 | 11:49 PM
silvercoupe97's Avatar
Default RE: 2g bov
Yes, it's normal.
Old Aug 14, 2008 | 12:03 AM
Default RE: 2g bov
ok so with a 1g i can actually hit 15 maybe 16psi( i know they dont go any higher then 16)?
Old Aug 14, 2008 | 06:55 AM
Default RE: 2g bov
nah i have seen where a 1g will go as high as 19psi. It can definetly get there on a 1g if you can find a crushed one
Old Aug 14, 2008 | 08:22 AM
Default RE: 2g bov
what exactly is a crsuhed bov?
Old Aug 14, 2008 | 08:44 AM
Default RE: 2g bov
exactly what is sounds like. They take a stock metal 1g BOV and crush it down a bit. As you can imagine this is tricky becuase you could ruin the BOV so doing it you have to know what your doing. But done right will allow the BOV to hold boost better.
Old Aug 14, 2008 | 10:28 AM
Default RE: 2g bov
this guy wants to sell me a 1gbov on the flange and a curshed bov for 25? good deal?
Old Aug 14, 2008 | 11:26 AM
Default RE: 2g bov
^^he wants to sell you 2 BOV's...i dont get it.and you dont need a flange for the 1g swap, it bolts right up to the stock flange
Old Aug 14, 2008 | 02:52 PM
Default RE: 2g bov
Not on a 2G. You need a 1G flange to go from a 2G bov. Plus, you'll want to upgrade the UICP to a metal UICP.
Old Aug 14, 2008 | 02:57 PM
Default RE: 2g bov
A stock 1G bov is known to be capable of 18psi. It depends on the condition and not all 1G bovs are created equal.
I crushed mine to handle 20psi. It could handle more if you do the Dodge Garage Mod too.
